Hi y'all. Looking for an .ies file to model a 25W T8 setup has been pretty tough. The majority of fixtures automatically use a 32W T8 for their .ies file. My question:
If I know the fixture, is it accurate to manually adjust the lumen output w/in the luminaire settings in DIALux? (ie, from 2830 mean lumens for the 32W T8 to 2280 for the 25W T8)
Thanks
Hey,
I'm glad you're showing interest in this awesome technology rather than being fixated on LEDs.
T8 is an anomaly as it's the only thing where the real world ballast factor and spec sheet ballast factor deviate significantly. Spec sheets assume 1.0, nearly always. I would use 2,000 to 2,115. This is assuming the more typical 0.88-0.9 BF, then the lamp's mean lumen depends on the type you use. The extra long life is a bit less.
Some IES spec sheet uses 700 series lamps while some uses HPT8, so that's why you see 2700 lumens on some while 2950 on others.
If you're using initial lumen value on the standard life 25W, it could be around 2,250 lumens.
If you need a higher precision value, you need to use the values from the lamp datasheet and ballast factor for the specific ballast when spec sheet and calculation war could affect the bid award decision, but otherwise, I think 1800 on "L" ballast, and 2,100 on typical/N ballast is close enough.
http://www.gelighting.com/LightingW..._4_Ecolux_25W_Lamp_SellSheet_tcm201-21073.pdf
