1 - 6 of 6 Posts
Hi,
I am working on a current system using a Bailey Differential Pressure Transmitter. Unfortunately the label is torn off, the only thing left is 0-150" H20 , 12-42VDC Max input, 1/2 NPT. Any chance that anybody knows the model number? It will be greatly appreciated.
Kind Regards,
24V
What is the process? This seems like something you should be able to find on the manufacturer's website. You could also call the distributor.
industrial E,I&C
Unfortunately we would need a lot more info as the code number contain details of the seating material.
This is really a vender question as with all industrial meters by the time you install them they are out of date and probably no longer available so anything you buy will have a different part number.
Bailey has been gone for 20 yrs...but all the info you need for a new DP transmitter you have although Bailey did sometimes not follow the normal 4ma to 20 ma standard on some of its products ....it's time to search the internet !
Knowing that it is 0 to 150" wc goes a long way to making use of it. 4-20mA Pressure transmitters are pretty ubiquitous. Knowing the above and the process material, you should be able to find a substitute pretty easily.
1 - 6 of 6 Posts
