A customer has low voltage can lights that are not working. I tested the magnetic transformer that supplies the 12 volts to the MR16 lamp. Each can light has its own transformer. The magnetic transformer is bad. It is about 15 years old. The nameplate lists it as manufactured in 1998. Electronic transformers are now plentiful at the parts warehouses and are relatively inexpensive. They are small enough to fit inside the can light junction box. I plan on replacing the magnetic transformers with electronic transformers (dimmable).
Can the dimmer switches that control these low voltage can lights be used with both magnetic and electronic transformers? Some can lights are still operational; some can lights will need the transformer replaced (with electronic). So a dimmer switch will control both types of transformers.
Thank you.
Thank you.
