1 - 3 of 3 Posts
cog
Does anyone use the Koyo DirectLOGIC PLCs? I would like to know if I can transfer the programming from one CPU in the 205 series with another, also from the 205 series. Specifically, migrate the data from a d2-240 to a d2-260. As far as I can tell, they use the same software and share a manual, but I am far from comfortable making any assumtions here.
edit: Appears the answer is yes.
Sweet Tea Addict
You found your answer, but to add to that,
No Problem using the same program in another cpu in the same series and you can also use a 305 or 405 series as well.
1 - 3 of 3 Posts
