If you use the arlington ast connectors you don’t they are built inThe correct answer is yes. If you were installing ac in old days. MC cables never required but ac did at least at one time. I don't hardly use AC outside of hospital stuff so not sure about any longer with the AC.
Does the red head go into the sheathing? I think what you have is an insulated throat connector. Does that take the place of a redhead, for instance in bx?If you use the arlington ast connectors you don’t they are built in
For what ever is listed on the box. Rh areDoes the red head go into the sheathing? I think what you have is an insulated throat connector. Does that take the place of a redhead, for instance in bx?
Is that bassackwards?For what ever is listed on the box. Rh are
For protection of the connectors not the conductors
The 232mscm stab it boxes I use have the ast built in and the far side support and the first support and a stud mount bracket. They are a little more expensive but pay for themselves in labor units putting all that stuff togetherSo why would an inspector fail a job for these not being used?
320.40So why would an inspector fail a job for these not being used?
Doesn’t apply ul listings supersede and this is MC .320.40
Yes that would be another option. But it achieves the same requirement. The question was "are these required". There are also other brands of connectors besides Arlington's ones. Insulated throats. They too can fit the bill.If you use the arlington ast connectors you don’t they are built in
