I can't figure it out, every time I try to put them on, they end up bunching up and twisting.
Thanks, I meant they are to make them more like a high voltage grips, I just couldn't get them on.SamoanThor said:Those fall under warranty. Strippers don't but lines, needle nose, *****, etc all warranty the grips.
If they are the hard red type, you have to get them in some hot water, just at a low boil, get them to soften and slide them on.Thanks, I meant they are to make them more like a high voltage grips, I just couldn't get them on.
