1 - 20 of 23 Posts
Hey guys I have a question about the older style cloth wire. Last year I was on a gig for about 5-6 months where we were swapping out old fuse block panels in a museum. The wires were the old cloth style of insulation. They were brittle and when bent the insulation would crack or break. Also when burnt the insulation didn't burn off entirely and left a very brittle white coating that was almost like a dust. Don't ask how I know I just do.
So anyways about two or three months after the fact someone said we could have been working with asbestos insulation the whole time. Does anyone know if there's truth to this?
Discussion Starter #4
Looks pretty scary. Hopefully I didn't bone myself at 23 years old as it would be setting in around age 50. We had a fair share of 277/480 and 120/208 blocks being replaced with breaker panels. Probably 30 or 40. Nothing I can do now I guess. It's surprising this isn't common knowledge throughout the field. I've been going through the apprenticeship for four years now and they havs never once mentioned this to us.
RIP 1959-2015
Start Smoking heavily :eek::laughing:
Since the first signs of asbestos-related illnesses may not begin to appear until 35 to 40 years after exposure, many thousands of smokers and former smokers could be suffering from the symptoms, unaware of the cause. Indeed, some have died without knowing how or where the asbestos exposure occurred.
Gee, I wonder why so many smokers died from smoking...
http://www.nytimes.com/2012/07/08/magazine/who-made-that-cigarette-filter.html
I've messed with a bunch of it. Other than the 15 minutes of coughing up blood every morning, I haven't noticed any problems from it :laughing:
I know that asbestos can also be found in older conduit seals in the fibre used to pack them.. If we are asked to remove them the whole seal and a section of pipe on each end comes out intact or it is sampled and analyzed first..
Senile Member
When I was a little kid in the early 60's, childrens pajamas contained asbestos.
Asbestos was in floor tiles,roofing tiles, siding, brake pads,wire insulation, some wallbording, etc. etc....
It was a miracle material used in all sorts of applications. Somehow those of us from that era are still around. Don't sweat it so much. Try to limit your future exposure.
Well that's some comforting news.
Experience Member
There are three types of asbestos used in commercial applications, but for electrical applications*crocidolite, or "blue" asbestos, had properties that made it an especially effective insulator, and enormous quantities of crocidolite-based electrical insulation was produced and applied to residential and commercial wiring, power lines, and the power generation and transmission facilities of the major utility companies.
Read more:*http://www.mesothelioma.com/asbestos-exposure/products/wiring-insulation/#ixzz3P8PZXQGq real good information
Most of the stuff I've seen is the old cloth covered romex with a white braided coating of the fiber over a thermoplastic coating. Is that why "cough" "cough" when you try to remove the fiber, you see little fuzzies floating in the air "hack" "hack" ?
I wouldn't worry as much about wire insulation as much as having drilled through old popcorn finished ceilings, and pushing up old ceiling tiles. Crawling on mill pipes running wires, pipes, and cable trays with covering worn off. What kills me, is that it doesn't show up on X-rays for 7 years.
Conservitum Americum
Dis guy is always interrupting my TV watching with his 18 Billion dollar Mesothelioma trust fund for those who have the disease from being exposed to asbestos in the past.
In my 20s, I worked 2 summers for a company that serviced and rebuilt sterilizers for hospitals, labs, etc. and most of them had asbestos insulation on them. When the scare first started, we got a lot of contracts to "seal" the insulation with this cloth/rubber combination, sort of like fiberglass layup. But in working on them, we were always disturbing the asbestos and inhaling it. 35 years later, I don't have any lung issues or problems.
That said, a friend of my brother, 10 years older than me, worked for the State for 25 years in an old office building that was later found to have air ducts in the HVAC system that were MADE OF sheets of asbestos. He has mesothelioma and is about to die of it, having been suffering from it for the past 20 years. He is going to die rich, for whatever that's worth, but way too young (68).
My point is, confirmed by my doctor when I asked, is that there is very little evidence that short term exposure causes mesothelioma, even though, as he pointed out, the asbestos fibers are likely there in my lungs still, because they never break down. But as he put it, there is a LOT of crap that gets trapped in our lungs, 99.9999% of which will still be there in 10,000 years if some archeologist digs us up. Our lungs can handle that, up to a point. The problem is, the constant barrage people get from long term exposure, day in, day out, overwhelms our body's ability to encapsulate it and render it harmless (or less harmful). Then on top of that, smoking, which nearly 90% of people in the 40s through 60s did, added the nice sticky tar to trap even more crap in there and compromise the entire system.
One project with a few fibers is not going to kill you, at least not before something else does...
1 - 20 of 23 Posts
