I just take a ground bar and tap screw it to to outside of the meter pan. They don't use those interconnect blocks anyway around here anyway, they always look to ground off the meter pan.Two of them went, right after the other.
Pot/pig metal trash...made in India.
That's not a bad idea. Never seen anyone use the IBJ.I just take a ground bar and tap screw it to to outside of the meter pan....
that would be classified as "code:sketchy, at best" :laughing:I just take a ground bar and tap screw it to to outside of the meter pan.
No, but no one around here is asking that question.Your ground bars are rated for exterior applications?
That thing looks stupid. even hubbell is going downhill.Two of them went, right after the other.
Is it copper/brass?Arlington had been making one for a while. Seems pretty nice and all the new homes I see have them
I use the Arlington one in Zinc, but I do believe that they make one in bronze.Is it copper/brass?
Only seen the zinc oneBuzzKill said:Is it copper/brass?
Yup. We have those and the zinc ones. Haven't installed any other brand, but have done quite a few arlingtons.nrp3 said:Put a bronze in yesterday, the kind the 1/2 pvc fits into to. Nice part.
id bet your life that it broke because it was torqued too hard.is overtorqueing a possibility?
You ever worked with pig metal?? It's CRAP. I could probably break that pos with my hands. It was anything BUT steel.id bet your life that it broke because it was torqued too hard.
