1 - 10 of 10 Posts
Are you feeding the lights and GFI separately or are you extending one of the circuits to another location?
Check 210.11(C)(3)
Working in a house right now that is getting partly remodeled. The one bathroom is being fed by a 2 pole 20 amp breaker. The outlet is separate from the lights. I'm just thinking if someone plugs in a hair dryer and straightener then the breaker trips and then the lights go out too.
Don't overthink...
You would be in the dark if a single pole breaker controlling the lighting tripped as well.
Right. If the gfci was on its own breaker, and not a multi wire circuit, then I wouldn't be as concerned. But it is on a multi wire branch circuit and overloading the gfci would cause the 2pole breaker to trip.
You could "what If" all day long and drive yourself crazy.
What if the transformer fails, you are still in the dark.
1 - 10 of 10 Posts
