I have a customer with drives on three intake and three exhaust fans on a roof. They've asked me to install local disconnects for the motors. I know that disconnects on the output of a drive is not an ideal situation. The current setup is a dedicated emt conduit with THHN to each fan, about 150'.
I'm considering pulling in 600v shielded cable with the 480v to each disconnect using an aux contact to an enable input in the drive. I'm trying to do this as correctly as I can under the circumstances while trying not to smoke the drives in the process. A separate control conduit would be ideal, but the customer said if I have to run another conduit, they'll just scrap the disconnect idea.
What do you guys think?
