What is the proper way to eliminate moisture from cables before megging them? These are 750mcm three conductor armored cables carrying 4160.
Would your answer change?Is this for a job or are you just curious?
Is it like a lead sheathed mv cable? Water inside a cable can be responsible for expediting the breakdown of already weak spots in the insulation. Drying a cable out doesn't always make things better though due to the impurities in the water that are left behind afterwards. I wouldn't think that water in a cable could produce a full blown fault but it's hard to say without knowing the type of cable and insulation in question.butcher733 said:I am spectating this at my current job. One of the cables isn't megging out and they want to rule out moisture. There was a fault that trashed the line side of a transformer and they are wanting to rule out moisture invasion in the cable. I don't see how this would solve anything though. Once a cable causes a fault it is trash IMHO.
Its pretty much teck cable. Plastic coated MC on a large scale. Armored tray cable by any other name.Is it like a lead sheathed mv cable? Water inside a cable can be responsible for expediting the breakdown of already weak spots in the insulation. Drying a cable out doesn't always make things better though due to the impurities in the water that are left behind afterwards. I wouldn't think that water in a cable could produce a full blown fault but it's hard to say without knowing the type of cable and insulation in question.
Exposed tray. I think that one theory is that the boot in front of the lug (stress cone?) Has moisture in it and is shorting the phase to ground.A cable isn't megging out? Is it overhead, exposed or underground? Maybe it's blown to pieces haha
Maybe contact the wire manufacture see if they have any recommendations?What is the proper way to eliminate moisture from cables before megging them? These are 750mcm three conductor armored cables carrying 4160.
Great ideaChris1971 said:Maybe contact the wire manufacture see if they have any recommendations?
Im not grilling you, Im just interested in hearing more about the impurities left behind part....Is it like a lead sheathed mv cable? Water inside a cable can be responsible for expediting the breakdown of already weak spots in the insulation. Drying a cable out doesn't always make things better though due to the impurities in the water that are left behind afterwards. I wouldn't think that water in a cable could produce a full blown fault but it's hard to say without knowing the type of cable and insulation in question.
Pure water is actually an insulator. But pure water (distilled) is not typically what we're talking about when it comes to water damage in a cable. Rain water is formed around dust and pollutants and ground water contains minerals and salts; all of this is still present after the water evaporates and however minimal the conductivity of the material it still can attribute to high resistance faults, especially in mvShock-Therapy said:Im not grilling you, Im just interested in hearing more about the impurities left behind part....
Then unboot the termination,megger,go from there.Exposed tray. I think that one theory is that the boot in front of the lug (stress cone?) Has moisture in it and is shorting the phase to ground.
We pulled in 15kv cables yesterday and the amount of water that came out of the conduit was enough to fill a small pool. The new cables tested out.Most electricians would choose NOT to re use wet cables,
Due mainly to legal liability issues,
But if you must ! Leave them out in the sun for at least a week.
