It is 40+ years old and still in use. Who provides it anyway? Plumber or electrician. I wanted to open it up to check it out. Just to see how it is built. Also for a manufacturer label.220/221 said:I've never seen it and I must say that it's one of the most useless things I've ever seen.
What city? Look close, this thing is all steel with the 120v receptacle for the washer and the 240v for the dryer built into the same unit as the water supply and drain.Service Call said:All the time. It seems that was the thing for condo laundry rooms. Almost everyone has that set up I thought that was the norm.
Central FL. I know. I see it all the time. Like I said, I thought it was a standard item.btharmy said:What city? Look close, this thing is all steel with the 120v receptacle for the washer and the 240v for the dryer built into the same unit as the water supply and drain.
Eleventy-billion. LolT&K said:It's called a Guy Gray box. Guy Gray is the mans name that invented it. He's from west Kentucky. Rascal made eleventy-billion dollars off that "invention"
