1 - 8 of 8 Posts
My idea is to instal an auto clutch between the motor and loading system. This would separate the motor from the loading system until the motor reaches a certain speed. The loading system should speed up slowly and not affect the speed of the motor.
Is this idea already being used? What do you think?
animal lover /rat bastard
I believe that centrifugal clutches were designed to do this ? (proper name: centripetal clutch). I'm sure there are more advanced electronic controls that do this now, but you go girl
Bilge Rat
motors and controls.........
A centrifugal clutch, similar to those used on go-carts, would work. Most of these will engage at about 2500RPM, so you'd need to use a two-pole (3600RPM) motor.
I've seen them with belt drive instead of chain.
Have you looked into a soft start?
What is your application? A friend installed a go-cart centripetal on his small air compressor without an unloading valve....works great.
Retired
They make motors that have a electric clutch between the motor and the output shaft. The clutch is electrically operated with a coil. Very similar to a foot pedal operated motor on a sewing machine.
Bilge Rat
You can also get them to mount directly to a C-face motor.
With most of them, the input and output shafts are in line with each other, most have a C-face on the output too.
The older eddy-current variable speed clutches were the same way.
1 - 8 of 8 Posts
