Are you going to need an E stop?
I worked in a chilled water plant and we had to install disconnects at every air valve so when they operated a valve for maintenance there was a way to prevent all signals from the SCADA to the valve and a way where you could physically lock out the valves.
Disconnects in this situation were switches when the valve was locked out it opened the signals from the SCADA system.
Might be time to call the safety officer if you get along with them.
