Hello,
I wanted to request insights into the requirements to provide emergency lighting unit in salt / sand sheds (100' x 50') which are classified under National Building Code of Canada major classification "F". These are low-hazard storage facilities which has a overhead door operator and manual door for entry/exit.
The NBCC mentions requirement to provide emergency lighting in "Principal routes providing access to exit in open floor areas". It does not specify applicable building classification types. I assume the manual door for entry/exit may classify as principal route providing access to exit, but I'm not sure if this mandates installation of an emergency lighting unit. So I thought to inquire if anyone familiar with installation of electrical distribution in salt / sand shed type facilities, would provide some insight into this requirement.
Thank you.
Thank you.
