I've had that problem with Topaz. You have to make sure there are no burrs on the cut end. Ream it like you are a plumber. Then I remember taking the connector or coupling apart and putting the ring on then the nut. Big PITA!
-Hal
-Hal
Not 100% positive, but I think regular compression couplings/connectors stopped being code compliant for outdoor use a few code cycles back. Most people now use the actual rain tight stuff with the blue or yellow gaskets.Are we talking about true RT fittings that are gasketed or the common compression fitting that we used to call RT?
I've never seen (in person) or touched one of the "new" RT fittings, they still have that split ring in them? Where does the gasket/o'ring (what ever makes it RT) go in the fitting?Not 100% positive, but I think regular compression couplings/connectors stopped being code compliant for outdoor use a few code cycles back. Most people now use the actual rain tight stuff with the blue or yellow gaskets.
Another thing that was totally code compliant since the dawn of time but for some reason the clowns that make the code books decided they weren’t acceptable anymore.
There’s a gasket on the inside. Kinda like a sealtight connector, except it fits over pipe.I've never seen (in person) or touched one of the "new" RT fittings, they still have that split ring in them? Where does the gasket/o'ring (what ever makes it RT) go in the fitting?
Your serious? How much pipe are you running a day like that??????If you use the tubing cutter and cut only partway through the wall and snap the tubing off at the score line, it leaves a slightly bigger smoother radius on the cut ends with minimal effort. The Rigid cutter works onEMT conduit from 1/2 to 2”
Why EMT and not PVC with expansion couplings as required in the Raintite area?One of my guys came this morning with a piece of 1/2" emt and a 1/2" rt coupling and showed me how it fit together. It did not slide together until I wiggled and jiggled and complained a lot. Is anybody else having trouble with raintight fittings sliding onto emt. We are using Wheatland brand pipe and Topaz fittings. We had a piece of Silverslick® pipe that did not seem to be as bad.
Are we the only ones having trouble. It seems like when they went to the rt fittings with the gland inside that things got really bad. I think that some of guys are taking them apart and throwing the phasic gland away do the water can get back out after it gets rained on.
Because PVC will have just as much moisture inside as EMT.Why EMT and not PVC with expansion couplings as required in the Raintite area?
But it doesn't rust.Because PVC will have just as much moisture inside as EMT.
-Hal
