Its brand new though. And its been a pattern with his other trucks.Heater coil may have a little leakage causing gfi to trip
You didnt have shoes on.We had them here years ago. When the block heaters went bad it hurt like a mother some mornings until we installed GFCI's.
You can guess what was wrong.
We parked the trucked nose to tail and touching 2 was shocking at times. The guy in the garage who made the cords for the plugs was nice enough to solidly ground the trucks frame. The bad part was the conduit that ran down the walls and loading dock was rotted and falling apart in spots. There was no ground wire run back to the panel.TOOL_5150 said:You didnt have shoes on.
True of virtually every protection scheme I can think of: GFCIs, fuses, motor overloads, breakers, protective relays, you name it. Rule #1: It's most likely not a problem with the protective device.95% of my 'gfci tripping' calls are simply due to them doing their job.
But what is depressing is that often the same people who would never even consider doing away with any of those items have no problem with getting rid of the GFCI.True of virtually every protection scheme I can think of: GFCIs, fuses, motor overloads, breakers, protective relays, you name it. Rule #1: It's most likely not a problem with the protective device.
Thats not depressing, thats natural selection.But what is depressing is that often the same people who would never even consider doing away with any of those items have no problem with getting rid of the GFCI.![]()
Does your state have an exception for that?i know its off subject a bit, but in my house my garage door openers, my basement freezer, and sump pump are not on gfi's. to me, i want all these systems to work. i have heard that newer motors aren't supposed to nuisance trip. why chance it. whether it being a buttload of spoiled meat, or having to get out of my car when its snowing to beat hell, to come home to a flooded basement. i liked the old ways. have a single outlet for each. maybe i will do assured grounding quarterly on all these...:thumbup:
When I was in the aquarium hobby I had some very long winded inter-webs arguments with people that hated GFIC, every now and then one of them would stop posting here or there. No obituary or nothing, they just stopped posting.95% of my 'gfci tripping' calls are simply due to them doing their job
in fact, i really think there should be a 'thank your gfci day' for all the incessant complainers out there to realize they may not have been around to beeeaatch w/o them
Yeah, for sure.i know its off subject a bit, but in my house my garage door openers, my basement freezer, and sump pump are not on gfi's. to me, i want all these systems to work. i have heard that newer motors aren't supposed to nuisance trip. why chance it. whether it being a buttload of spoiled meat, or having to get out of my car when its snowing to beat hell, to come home to a flooded basement. i liked the old ways. have a single outlet for each. maybe i will do assured grounding quarterly on all these...:thumbup:
As long as it happens to the person who takes out the GFCI I agree with you.Thats not depressing, thats natural selection.
