What type of work are you pricing?A there an app for a program on estimating? Or should I buy and install a program on my PC? And what is the easiest program out there to learn?
HARRY304E said:What type of work are you pricing?[/QUOTE
Wiring new additions and replacing fixtures
Wiring new additions and replacing fixtures in old workHARRY304E said:What type of work are you pricing?
I use ES2 flat Rate , check it out.Wiring new additions and replacing fixtures in old work
Thanks I willHARRY304E said:I use ES2 flat Rate , check it out.
Is that a month to month payment or can you buy it right outHARRY304E said:I use ES2 flat Rate , check it out.
One time payment or monthlyHARRY304E said:I use ES2 flat Rate , check it out.
Month to month..:thumbsup:Is that a month to month payment or can you buy it right out
Thanks I will try it outHARRY304E said:Month to month..:thumbsup:
The only app that I know of was for the old palm pilot. Also you could try Electrician's Toolbox for links to estimating software. Hope this helps.A there an app for a program on estimating? Or should I buy and install a program on my PC? And what is the easiest program out there to learn?
