I searched the site a bit, but never saw a discussion on the repair of the Class 1 division 2 Ex enclosures for switching equipment.
I run in to this a lot, where someone mistakes the threading as the NC Corse standard and decides to try to fit the selected bolt in to it. Resulting in a broken bolt or one that now cannot be removed with out drilling and re-taping the bolt hole.
I have never seen a enclosure that was not, a Quad lead threading. I'm sure there are a few.
For the apprentices that are getting in to this area. The study of the different machine threading and how to properly tap and die material is a good study.
Below is the differences of the types of bolt threading that is available.
The application of the right lubricant and threading lubricant to prevent electrolysis of the material is also important.
So How many of you run in to this with the Ex enclosures?
Do you have other repair procedures that you can share?
