1 - 2 of 2 Posts
Have a job that I installed 2008 using EasyHeat floor heating cable. Was about the time that they changed over from single wire return to 2 wire no return type, DFT 240 Volt type installed. Did 2 rooms and a hall, I poured self leveling floor over concrete and wire using a pre bonding agent as suggested by self level instructions. Went for 6.5 years and then they started to fail. Found all of the shorts or opens, using a easy heat test box. Repaired 3 problems, worked for a while then started to fail but not in same places. Repaired again, failed again but not in same place (again)
Well I am giving up repairing going to replace. My question is kinda a poll actually. Whats the most reliable out there , always used Easy Heat, Did maybe 25 installs over the last 15 years never had a failure at least that I heard about. Oh BTW guess who the homeowner was ......Me. Guess its better than a customer
Electrical Simpleton
1 - 2 of 2 Posts
