That works if you have the Edison-base fuse. Not so good if they've screwed in the tamper adapters.I have screwed one in the old main range and four panels. works but you better know what your doing.
This is also the process utilized with the light bulb method, but if you use an extension cord and keep the light bulb where you can see it you know the minute you clear the fault.I use the divide and conquer method.Process of elimination.
All the time. Basically the way I do it is divide and concur until the light goes out. Also when an amp clamp is used the current after the fault is always zero, before the fault its what ever the bulb is pulling. Speeds up pinpointing the fault. The method however works only on bolted faults, phase neutral or phase ground. Remember to unplug any loads on the circuit as well.Any of u guys ever use the lightbulb in series trick?
Ive seen it done but never used it?
Someone care to explain it
