Is there a program out there that any of you are using to do Fire Alarm layouts, as-builts, etc? I'm hoping for a less-expensive alternative to AutoCad...
No. I use autocad 2011 and excel for my calcs. What systems are youWireman5000 said:Is there a program out there that any of you are using to do Fire Alarm layouts, as-builts, etc? I'm hoping for a less-expensive alternative to AutoCad...
If you want I can email you a fire alarm template that I use for all my drawings. Just give me your email and what version of cad you use. That way you can do it in house.Wireman5000 said:We use Edwards. An engineer that I know just mentioned ProgeCad. Plus ConEst has a program for overlaying PDF files. We use ConEst for our estimating, so the add-on would be potential. I'm not opposed to subbing out the drawings, but I've had a bad experience with that in the past...
bd, mind sharing that template with me as well if possible? Thanks.If you want I can email you a fire alarm template that I use for all my drawings. Just give me your email and what version of cad you use. That way you can do it in house.
Yea send me your email. It's going to be a notifier template. All you have to do is change the company name and information on the layout tabs. The symbols are NFPA 170 2013 compliant. I could send calcs if y'all used notifier, firelite, and silent knight. Can't send y'all any of my honeywell stuff though lolGiorgio.g said:bd, mind sharing that template with me as well if possible? Thanks.
Sent me anything you might have, I will sort it out once i get the templates and see what i need, better to have more than not have enough. PM sent!! Thanks.Yea send me your email. It's going to be a notifier template. All you have to do is change the company name and information on the layout tabs. The symbols are NFPA 170 2013 compliant. I could send calcs if y'all used notifier, firelite, and silent knight. Can't send y'all any of my honeywell stuff though lol
No problem. I will send it to you in a bitGiorgio.g said:Sent me anything you might have, I will sort it out once i get the templates and see what i need, better to have more than not have enough. PM sent!! Thanks.
Thanks so much!:thumbsup:No problem. I will send it to you in a bit
I will be home in a hour or so. I will email you when I get home after dinnerGiorgio.g said:Thanks so much!:thumbsup:
Thank You!I will be home in a hour or so. I will email you when I get home after dinner
Check your email. Just sent themmadbubba said:I would love the templete if possible. [email protected] Regards, Mike
