Okay its been a few years since I have done any firealarm system and now am currently installing a Simplex Mapnet II/ IDNET system with, my question is. When you have a Simplex Addressable Relay IAM for fan shutdown can the 24volt power from the IDNET cable that goes to the addressable relay IAM be used for your common on the C contacts of the relay portion of the IAM (which from the relay portion will go to a MR 201 relay to break the control circuit for fan shutdown). We had the Simplex rep out on the job the other day and I took it one way and my toolie took it another way . I say we need a separate power source ie: 24v supply from the Simplex FACP he understand that we can use the 24v from the IDNET cable used for the relay IAM and the rest of the system.
