Seen at home depot
Edit: Read the rest of the thread
Right there. Most sprinkler drops like that would have a drain and a tamper switch I thinkBig John said:You sure that's not part of their plant misting system...?
I tend to agree but the fire alarm being sprayed 48 times an hour is funnier to me :laughing:Whatever it is it's zip tied to a column. Fail
It's all good, it would normally be a wet location horn strobe in the garden center.Haha I hope that was sarcasm, it was a play on words. Yes it is the plant watering system. If you look closely, you can see the residue building up on the fire alarm.
I have my doubts after the amount it has been sprayed.It's all good, it would normally be a wet location horn strobe in the garden center.
Do you do a lot of fire alarm installation and servicing?I have my doubts after the amount it has been sprayed.
The horn/strobe is monitored by the FACP. If anything goes wrong with it, the FACP will go into a trouble alarm.I have my doubts after the amount it has been sprayed.
Oh, no doubt, I just don't think they would notice at this particular home depot.Do you do a lot of fire alarm installation and servicing?
If the horn strobe was getting wet inside it is very likely the fire panel would be reading a ground fault or short circuit.
Fire systems are monitored and when there is a problem typically the panel dials out to a central station notifying them there is a problem.
They don't have to. The monitoring company would be notified and would call the manager.Oh, no doubt, I just don't think they would notice at this particular home depot.
Which do you think came first? My vote is for the horn/strobe.Meh. I just thought it was interesting placement. Oh well. Never mind![]()
The horn strobe, they installed this new rainwater plant watering system somewhat recently.They don't have to. The monitoring company would be notified and would call the manager.
When I go to troubleshoot an intermittent earth ground trouble, one of the first things I check is the outside beacon for evidence of water intrusion. If the trouble is in when I arrive, obviously I meter everything to find the ground. If the panel is clear then the beacon is where I begin the search for the needle in the haystack.Do you do a lot of fire alarm installation and servicing?
