So I made up my first panel today on a trim out. Took a picture for bragging purposes but also to remind myself 'wow, that could look a lot neater'. Anyone else do that?
over 30 & still do on occasion :thumbup:16 years and I still do that.
Unless you have NEC amendments those cables entering that way are an NEC violationRemember, first time. It can only get better. And yes, there's a couple joints. I forgoted arc faults needed neutrals.
Not true, you can have as much cable sheath inside as you want.Remember only a 1/4" of sheath is allowed in a box and panel.
Really?WhitehouseRT said:You have neutrals and bare grounds terminated on the same bar: code violation
Not in the USA it ain't. Is the op from Canada? On iPad and can't see locations.WhitehouseRT said:You have neutrals and bare grounds terminated on the same bar: code violation
QUICK get that ground rod wire & water pipe ground wire off that neutral bar............that's for neutral wires only.You have neutrals and bare grounds terminated on the same bar: code violation
