1 - 9 of 9 Posts
Can you use the same fittings/connectors for liquid tight(metal inside) and non-metallic liquid tight. Also, is corrugated tubing rated for outdoor use? I want to run fiber optic/belden wire through it. I know liquid tight is better , but im looking for a cheaper option
· Lurker...
I do not believe any of the ENT (IPEX or other brands) are outdoor (UV) rated. http://www.ipexelectrical.com/Content/Products/Product.aspx?IsDownload=true&FileId=455
I would suggest a NM Liquidtight conduit (ex. CARLON) with appropriate, listed, fittings. Most of these systems are rated for outdoor use. If you need more crush resistance, then select a metallic Liquidtight conduit (LFMC). Its more expensive, but will also do the job.
LJSMITH1 said:
I do not believe any of the ENT (IPEX or other brands) are outdoor (UV) rated. http://www.ipexelectrical.com/Content/Products/Product.aspx?IsDownload=true&FileId=455 I would suggest a NM Liquidtight conduit (ex. CARLON) with appropriate, listed, fittings. Most of these systems are rated for outdoor use. If you need more crush resistance, then select a metallic Liquidtight conduit (LFMC). Its more expensive, but will also do the job.
Hey great answer thanks. I have plenty of metallic liquid tight and fittings. If i get the nm liquid tight can i use the same fittings as the metallic?
1 - 9 of 9 Posts
