Your going to place the POA above the weatherhead?
That looks like the original location of the POA.Your going to place the POA above the weatherhead?
Ya why? I forgot to take a pic after poco hooked me back up, looked good.aftershockews said:Your going to place the POA above the weatherhead?
What was the height of the current POA location?Ya why? I forgot to take a pic after poco hooked me back up, looked good.
I would have pushed the slack out the WH.You need to buy a pair of cable cutters... those rabbit ears on line side in meter pan look like a mistake.. sorry to put it that way..![]()
I would of put it in the scrap bucket... there is enough cable at the weather head...I would have pushed the slack out the WH.
I wouldn't have ordered that much wire.I would of put it in the scrap bucket... there is enough cable at the weather head...
No mistakes fella I like to leave extra just in case of changes, the load side feeders are short because that's All I hadpB4T said:You need to buy a pair of cable cutters... those rabbit ears on line side in meter pan look like a mistake.. sorry to put it that way..![]()
YessirPete m. said:Is that metal LB bonded from the panel? Pete
I doubt any changes made in the future will ever take advantage of the slack you have on the line side of that meter can.No mistakes fella I like to leave extra just in case of changes, the load side feeders are short because that's All I hadp
What's the white #12 or 14 doing in the disco?
1 looks like maybe a bonding locknut? the other looks like a tap for a circuit.What's the white #12 or 14 doing in the disco?
Water bond and locknut bondChris1971 said:What's the white #12 or 14 doing in the disco?
Looks like the other is using both black and white twisted together and used as an EGC?1 looks like maybe a bonding locknut? the other looks like a tap for a circuit.
