I actually think that might be true, but I can't confirm that. I seem to remember a max gap between the box and the gypsum, above which you had to use fire caulk or similar intumescent seal. The use of rated device boxes in fire rated assemblies is covered under the UL Orange Book, of which I do not own a copy. It's actually a 2 volume expensive affair. The NEC is mute on the matter.
