Remove the dimmer(s) from the equation and tell us what happens. Replace with standard switches.Did a bathroom the other day and installed a 3 gang box ( fan ,recessed, vanity)the vanity lights flicker when on full high, I've changed the dimmer checked connections and breaker. The other dimmer in the box is an LED dimmer with LED recessed. The lights both flicker and it's almost like the lights have a pulse to them , but if I dim the lights a tiny bit the dimming stops
