Try this. Low volt, 120v, all together. Never tried one, but take a look: http://www.aifittings.com/whnew98.htm
This is a pretty cool wall box too:
http://www.fsrinc.com/products/PWB-100.htm.
FSR makes all kinds of cool floor and wall boxes.
Probably more of a commercial item though.
Jacob
Shut UP!! what you know about AC/MC cables mind your own BUsniess thats power work not low voltage!!!!!!:no: I have NO respect for you!!!!I do a lot of commercial and one problem with the plastic boxes is that you can't use them with AC or MC cable. That leaves the FSR which is expensive and not readily available.
-Hal
With the propper connector.Mr. Biss the DataCom 45-0021 can be used with a metal or plastic back box. There is no reason that it can not be used for ac or mc cables. The Arlington box has a 1/2" knock out in it and there is no reason it cant be used with a single mc cable.![]()
Good one Jake. I've never used these but they look pretty slick.
I used this one for my TV, looks great and went in easy.This is a pretty cool wall box too:
Jacob
