1 - 13 of 13 Posts
Electrical Simpleton
Typically, you have to cut the existing slab and extend the conduits.
It's done all the time. What is your question?
Pete
Yeah supposedly the HO had the GC cut the slab over to the locations. They are removing a wall to open up the floor plan in the house. I'm going to run some 1/2" PVC over to the locations. My question is what boxes to use. The ones I've used for floor plugs on new homes are the big gray pvc one's that are like 8 or 10" deep and like 6" diameter. so not sure what to put in existing concrete.
There are several options (google is your friend) but I think Carlon makes one that you can saw flush with the concrete when it is poured.
Pete
Reactions: robmac85
The carlon floor boxes are real nice. Just set the box, no need to worry about the finished height let it stick up a bit. Then when your ready to install the cover, after the finished floor is down, just cut the plastic box off flush with the floor with a sawzall. I like to use them whenever I can. I think these are the only carlon boxes I actually like!
corn-fused
OMG! carlon gonna make nothin work right!:laughing:
1 - 13 of 13 Posts
