So in few week i will have to do alot of ballast replacement on fluorescent fixture T5/ho 6 lamps that work on 347v in the storage section where the roof is about 50ft high. we got possibly hundred of fixture like this in this section.
They are all working with movement sensor also and it's a farly new installation maybe 3-4 years old.
And i was wondering what could be the safest way to change them ?
And also find a way to disconnect this without having to shutdown the lighting of all that storage or working with a flashlight lol.
I was planning to do this: (Feel free to add suggestion or something )
I will check if the breaker of these lighting hopefully is separated by section row for this storage.
If yeah i would put a lock on that breaker than close the entire row with cone and safety tape to avoid lift truck to come in while im 50ft high on a skyjack lift.
Was thinking to bright maybe some big lamp with me up there i could hook on my skyjack lift to help me see something because the power would be down for this row.
Disconnect all the fixture that need a ballast replacement of that row and bring them down and repair them in the shop and once its done put them all back up there, remove the lock and open the power of that row
and repeat
I bought also a bunch of Wago connector to make thing go faster.
and repeat
