Thanks...Your question is garbled.
There 8’ because my grandpa was a nut. He passed away and now grandma wants LEDs, she admits though that even the current lighting is a bit much. My plan was to swap with 8’ LEDs and put them on a dimmer. I just can’t find any 8’ LEDs with Triac dimming and don’t want to run additional 0-10 wires. So the 4’ers seemed like the next best option. I had the same concerns as you mentioned though…the dispersement of light. Any and all suggestions are welcomed.Are you talking about replacing 1- 8' fixture with 1- 4' one?
Shadows will not be your friend. You just cut down the area covered, why were they 8'?
Cowboy
I did (2) 2 tube 4' LED shop light fixtures for each 8' one at my house. I would not worry about dimming unless a lot of time is spent in the area.There 8’ because my grandpa was a nut. He passed away and now grandma wants LEDs, she admits though that even the current lighting is a bit much. My plan was to swap with 8’ LEDs and put them on a dimmer. I just can’t find any 8’ LEDs with Triac dimming and don’t want to run additional 0-10 wires. So the 4’ers seemed like the next best option. I had the same concerns as you mentioned though…the dispersement of light. Any and all suggestions are welcomed.
They look like this. I converted about 100 in a grocery store.This may or may not be helpful but :
You can buy a kit for an 8' strip that will convert it to 4 x 4' bulbs, but it will still be a strip, no covers
I liken the difference between most LED lights and fluorescent is think of a drop spreader and a broadcast spreader. If both are paying out the same amount of fertilizer the drop spreader will be more concentrated in it's coverage while the broadcast spreader will be wider and more even. Some people understand the analogy.You can buy LED fixtures that throw light in all different patterns. LEDs are basically one directional and it sometimes makes a difference. It's hard to find LED fixtures that will match the wide even lighting that fluorescent tubes throw. With an extra four foot gap between fixtures, even if the lumen output is the same, it won't be as even.
