You are converting Kw to watts.
Since you are multiplying kilowatts by 1,000 you are getting a larger number in return, which is watts.When working with "kilo" anything, the result of the operation will also be "kilo." "Kilo" is just another way of saying ten to the third power. If you multiply "kilowatts" by 1000, you get "megawatts." No way around that.
Kilowatts x 1000 = watts. Period. It is not megawatts. 1000 kW is a megawatt.I have a question. Looking in my Ugly's Book for relevant, three-phase formulas, I found one for calculating amperes when "KW" (kilowatts) is known. The formula has KW X 1000 being divided by the product of voltage, power factor, and 1.73.
If the power is already KW, why is KW multiplied by 1000?:001_huh:
K or Kilo means 1,000I have a question. Looking in my Ugly's Book for relevant, three-phase formulas, I found one for calculating amperes when "KW" (kilowatts) is known. The formula has KW X 1000 being divided by the product of voltage, power factor, and 1.73.
All these online conversion calculators say your wrong. :thumbsup:Inphase277, you're flat wrong. One KW multiplied by 1000 is one MW. One KW divided by 1000 is one watt.
As I wrote, KW is another way of expressing thousands of watts. One KW is 1000 watts.
What do you think "kilo" means?
3Kw = 3000 watts...agreed?If you multiply "kilowatts" by 1000, you get "megawatts." No way around that
Wrong.Inphase277, you're flat wrong. One KW multiplied by 1000 is one MW. One KW divided by 1000 is one watt.
