1 - 20 of 28 Posts
When about to feed 4 500's and a 1/0 ground through a 4" LB and somebody suggest feeding the wire in from the back and then down through the bottom what is the first thing that strikes you?
I should probably add that the reason they wanted to do this is because they wanted to terminate the wires inside the mdp because a sharp bend and how close the lugs were to the 4" in the cabinet. So, the wires coming into the LB had already been terminated before they were to be pushed down through the bottom of the condulet.
· Salty Member
If you have a non-arbitrary BBQ approved method of describing LB opening positions I would glady adopt it.:)
Well really I could not care any less which way up it is but in my view there is no 'right way' to feed wire into it. Each job has it's own situation.
But unless its a mogul LB its a NEC violation in either direction.
1 - 20 of 28 Posts
