I have fuses blowing with no reason in the starter of two identical motors
Last time it happened both fuses on the A phase blew.
Inrush current duration is well inferior to the time delay curve of the fuse but some reason it blows once in a while
Multiple measures have been taken at different times. Volts and Amps are normal at all times.
What could be the problem?
