fellow electricians. I'm looking for recommendations on garage lighting. Said garage is used as a workshop and the owner is looking for something that will be plenty sufficient for seeing lines on a tape measure and grains of the wood, etc. The ceiling is about 11 feet off the ground. Currently he has 8' t12 with non electronic ballasts that struggle in the cold. He keeps it at about 45 degrees in the winter. Unless I see any suggestions as being better than tandem 4' t8 fixtures I will do that. There is already strut mounted where the old fixtures were so any recommendations for fixtures with high heat wouldn't be an issue. Thanks
