Having a gas fire place insert installed in an masonry fireplace. This unit is not direct wire in fact is corded. The manufacturer’s instructions say to either run the cord out the front to a nearby outlet. Or install an electrical outlet on either the left or right corner in back on the existing masonry fire box.
I do not see how this would pass any code requirements the outlet could never be serviced with out removing the insert.
What do others see.
I found another post but the consensus was follow what the manufacturer suggests.
We follow the 2017 NEC
What do others see.
