13301 - 13320 of 13322 Posts
I think I need to switch back to commercial projects. This experiment in resi is starting to grow long in the tooth... Ended up removing it all and running new from the attic on an adjacent wall. They cut or notched a significant portion of a load bearing wall!
Electrical wiring Machine Electronic device Electronic component Auto part
Font Monochrome Art Monochrome photography Metal
Brown Wood Rectangle Wall Paint
I believe that is code compliant.
that said, I have used a blank cover plate on both sides and think it’s a better installation
The only issue I see with the two blank approach is it gets pretty thick and you run short on threads, especially with pvc box connectors.
