well at least he didnt use the last 3 steps of the ladder ....... 🤣
more like, this kids, is why you don't do your own electrical, unless you are an electrician. You can tell by how that romex is stripped that an electrician did not do this. I wouldn't trust a homeowner to do any sort of connection properly, pre-twisted or notView attachment 167211
Service call this morning. They could smell smoke.
This kids, is why you always pre twist the wires.
Nope. That is why you make sure you actually tighten the wire nut!This kids, is why you always pre twist the wires.
Sometimes, extra pre-twistiness is required.
i do not try to twist enough to twist the insulation, sometimes it ends up with one or twokind of makes me wonder if they had one of them fancy wire nut twisters that go in cordless drill or impact driver.....
There's a good chance that it does comply with the old 6 throw rule. The left vintage GE panel appears to be the "main" panel while the CH panel and right vintage GE panel are "subs". You can just make out a nipple between the 2 GE panels. I count 4 throws to kill the electricity.Who needs six movements of the hand when you can have 30! There's no main here or outside, GRC exits the meter, enters below the garage slab and stubs through the foundation here in the basement. The CH panel was installed at some point for a pool. How was this ever complaint? How was the house sold this way? Why the yellow checkered flags painted on the walls? So many questions.
Seeing the CNC machine with open conductors reminds me of a good story.Wiring up a new CNC machine today, walked over to the other side of the shop and found this GEM. Apparently it's been like this for a couple years. You can even see all the oil buildup on the wires. Machine was running.
You really should have pulled covers so we could see how they got all the panels connected.Who needs six movements of the hand when you can have 30! There's no main here or outside, GRC exits the meter, enters below the garage slab and stubs through the foundation here in the basement. The CH panel was installed at some point for a pool. How was this ever complaint? How was the house sold this way? Why the yellow checkered flags painted on the walls? So many questions.
Doesn't really matter. It's getting replaced with a service upgrade 😁
what is that ? half of a threadless rigid connector?At a sawmill I was at today. View attachment 167459 View attachment 167460 View attachment 167461 View attachment 167462
It is a myers hub stuck into half of a LFMC connector. No idea why anyone would do that.what is that ? half of a threadless rigid connector?
they really should have gotten a galvanized reducer bushing
with no boots on the roof penetrations
there should at least be silicone or something to fill the gap
doesnt water run right on down in there ?
So that conduit with the 1/2 myers hub is just jammed into the 1/2 flex connector? No mechanical connection of the conduit to the box? WOW!It is a myers hub stuck into half of a LFMC connector. No idea why anyone would do that.
