FIFYSo that conduit with the 1-1/2" myers hub is just jammed into the 1-1/2" flex connector? No mechanical connection of the conduit to the box? WOW!
That looked like 2" to me. Those were 1/2 fitting, right?FIFY![]()
ooohhhh ..... now i see what you meant LOL , ok half of a fittingThat looked like 2" to me. Those were 1/2 fitting, right?
It's actually 4". There is no protection whatsoever on the wires at that point either. That goes straight from the generator to a disconnect. It is a Myers hub without the lock utility, stuck in the hub part of a sealtite connector. There is also a piece of 4/0 or so mine cable that leaves the generator head with protection, and runs at least 100' across the building to feed a fused disconnect. That is a 670 KW generator.That looked like 2" to me. Those were 1/2 fitting, right?
Do you always follow ALL the rules?and yes it belongs in this thread lol
you must not own a hacksaw
you should have avoided 2 of the bends on the next to last pic
if these pics are one single run of pipe ? i have counted approx. 720* in the pics alone
making accurate bends is not all there is to running pipe
picking a path that gives you the best route matters
planning your bends so that you use the least possible number of degrees in the run matters
did you know that 360 degrees is the maximum allowed by code and by physics?
did you know that experienced electricians try not to go over 270 degrees ?
Is it central vac pipe?have you pulled any wire in it yet ?
Throw enough mud at it, eventually it sticks lolthat is some ugly mud daubing he is doing , wonder if it will stick ?
Safety squint!Throw enough mud at it, eventually it sticks lol
Dont see a welding helmet (might be wearing goggles) so he's welding with his eyes closed
Dayum he must be making bank!Looks like he is making a rack for a Ford 150 so all the trunk slammers can carry their ladders (that they steal from the job sites).
Cheers
John
