I'll call him back and see what code he is referring to as it's obviously not NEC. The gas guy also doesn't know what he is talking about.Not sure what the inspector thinks armored cable has to do with bonding. Check 250.104(B)
It's not CSST. HOpefully I can get a hold of him tomorrow. I'm thinking that maybe the house gas was never bonded and that is all he wants?Csst bonding?
Depending on where you live, the inept or will say it's the plumbers job. Just run a #6 from a water clamp on the gas pipe to either the panel or another source of GEC
I'm pretty sure it's bonded inside the generator, correct? It's a 17kw Generac. Would he want the bonding to jump the flex? I've never seen that.Do you mean the supply from the house or the drip tee at the generator after the rubber flex line if that's what the gas guy did.
