I have received an invitation to quote the installation of camlocks for standby generators to enable connection and operation of load bank testing.
Most of these are 150 kVA units, with one larger, and 2 smaller.
I believe they will have one load bank testing device which they will transport from site to site. The installation of the camlocks would make the periodic testing an easy procedure.
Have you ever done this type of work, and did you install them at the generator unit, or at the transfer switch? Did you provide a panel or enclosure, or leave them hanging on pigtails?
I believe they want to be able to perform these load bank tests without affecting the utility connection at each site.
