I have been a lurker on this site for some time and have found a lot of useful information here. I have a question that I haven't been able to answer by searching.
Background:
I am working on installing a 480 V 3-phase 70 kW 3-71 Detroit diesel generator under a railroad passenger car. The generator and control panel we are using are second-hand, and of course I have no manuals. I managed to work out how the control panel works and have wired it and the various gauges on it to work. The system is set to start and stop the generator automatically when the "hotel" power provided by the locomotive or ground power is turned off. The only part of the system that I can't get working is the voltmeter.
When running off the generator, the output is right on at 479 volts, and 60.01 Hz. Thanks to the electric governor on the system, the output is rock solid. The car is wired to run large loads at 480, and uses 208 wye for the smaller loads.
The voltmeter appears to be calibrated for 240 volts. I installed a small 480x240 240/110 general purpose transformer between two legs of the 480 VAC from the generator. The problem is that I am getting something like 265 volts from the transformer, which makes my voltmeter read 530 volts. Nominally, I should be getting 240 volts out of this setup. Any suggestions as to why I'm not getting the correct voltage?
Background:
