I forgot to mention that I am located in New Jersey.Hello my electrician friends,
I am working on a project and have question on breakers that I will have to use.
1. Smoke detectors (6 total hard wired 120 v) connected inside electrical panel with 10 LED recessed lights (on a 20-amp ARC fault breaker)
2.Garbage disposal with regular 20-amp receptacle under sink protected with 20-amp GFCI breaker (own circuit)
3.Dishwasher with regular 20-amp receptacle under the sink protected with 20-amp GFCI breaker (own circuit)
4.Kitchen lights (4 LED) and 16ft of tape lights with 120v transformer in assessable cabinet and few pendent lights and fan in family room protected with 20- amp dual function breaker.
5.Refrigerator i think it might be 6 ft away from sink so regular breaker but if not protected by GFCI breaker.
6.Counter existing receptacle protected by GFCI breaker just adding two new receptacle that will be protected by GFCI receptacle in the counter will be fed from 20-amp regular breaker.
7. Receptacle in family room and hallway protected by 20-amp arc fault breaker.
8. Running new circuit for two receptacles in bathroom for double vanity that will be protected by GFCI receptacle (regular breaker in panel) and running new circuit for lights in the bathroom that will feed two vanity lights and 3 recessed lights in the bathroom and exhaust fan (homerun in the panel will be regular breaker or do I need arc fault?)
Can someone explain it to me if I am correct on the breakers in particular situations. Thank you for the help
