1 - 13 of 13 Posts
I have a little job I'm working on kind of a bar /pool house thing.
My question is ,if I put three resi ceiling fans down stream of a gfci rec circuit do you think I will end up with nuisance tripping of the gfci rec?
Thanks for your input!
Sent from my iPhone using electriciantalk.com
Estwing magic
That's the thing they will be on the load side .
I have three recs protected by one gfci , and was going to come off the last one to feed sw to fan
Three? I thought the max was two (but it wouldn't be the first time I was misinformed).
I would run the extra 60' of wire. Taking down ceiling fans to troubleshoot would be a complete PITA.
I see no problem with it. Worse case scenario you go back and install 2 extra gfci receptacles if you start getting nuisance tripping.
Is that a rule 99, never been called on anything like that before.
I,ll put 3 or 4 on the outside of a house off one gfci rec.
1 - 13 of 13 Posts
