1 - 20 of 31 Posts
Looking to get some sharp bits for drilling metal. The ones that came with my makita suck.
Would I go wrong with this set?
http://www.amazon.ca/Bosch-TI18-Titanium-Assortment-18-Piece/dp/B0000TZZWE/ref=pd_sim_sbs_hi_6
Any other good ones?
I bought a cheap set from Harbor freight...titanium, I believe. It hung up on me and when I reversed the drill motor it twisted 360 degrees and popped out without breaking. I'm hoping to have a situation when it hangs up in reverse so I can straighten it out.:blink:
Mainly I'd use these for mounting boxes and drilling pilot holes for strapping BX and EMT in the warehouses we do. I often have to drill into hardened (steel?) I think it's hard on my bits. I have to RAM a self tapper with all my might and sometimes they still won't go through. My drill bits have no chance. I've borrowed other guys (black) drill bits that do the job I just want some decent ones of my own, not sure if I should go titanium or cobalt for this purpose.
· Data Tech/Apprentice.
I just but HSS drills, I have a 1 - 10mm index and replace them as consumables as they break. I dont think that titanium and black oxide stuff makes a difference.
· NO high voltage here
bees wax works 1000x better then cutting oil, so my guess is he is serious.
Use it all the time when working on jeeps and motorcycles.
It is the best for aluminum, and works good for steal
also, check out boelube. Made by boeing, and its the ****
· Senior Lurker
This is awesome. I've never heard of using wax.. but if it's true, that's way more realistic to carry around than some little can of oil that will leak all over the place.
Thanks for the tip! Will try it.
Wax is certainly cleaner on the job. This is the real reason why Boeing uses a similar product. Ive spent almost 20 years in a machine shop. Ive learned a thing or two about drilling and cutting. :laughing:
· Senior Lurker
1000x? :rolleyes: Id agree if the fluid is trying to drip in my face.
Those DeWalt colbalt bits with the pilot point are good for thick steel, but can be overly aggressive on thin stuff.
I agree. I've been using these for over a year now and had 2 break on me. They straight up tear through enclosures, angle, I beam, and even stainless in no time. I just use lots of tap magic and swap the bits out every 3 or 4 holes. The only downfall is drilling into live enclosures, they tend to pull into the box, no matter how much counter pressure you apply.
1 - 20 of 31 Posts
