Status
Not open for further replies.
1 - 2 of 2 Posts
Hey doing some smart switch install's here in AB Canada, and I'm not a 100% sure with the grounding code or what's the proper way of doing it.
Am I able to run two ground wires under the same screw ? As well all of the grounds were cut short as you can see in the picture so i cant really pigtail them.
What's the proper way to go about this, picture attached.. and any help is much appreciated
Wood Electrical wiring Electricity Cable Gas
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area. If you are permitted by law in your area to do your own electrical work, please sign up at our sister site, www.DIYChatroom.com where many of our professionals are also members and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed.
1 - 2 of 2 Posts
Status
