This is located on a street corner on a large commercial property. I could not locate the circuit breaker for this, because in the (2) electrical rooms, not all of the breakers were labeled. There wasn't even any 3 pole 20A or 30A cb's, so I'm guessing that this is fed with a larger breaker that serves several pumps around the property. Each one having there own disconnect and controls. Mounted on strut, in an enclosure. There was also an outgoing wire that I didn't reconnect, until I hear that something is not working downstream.
I guess the key words are "structure" and "feeder" if it serves more than one pump ? I will have to get dig alert out there before I install an 8' rod in this busy area.
