On top of that.
My Client also had a transformer to generate 120/240v with neutral.
Problem is the so called idiot ran 1#6cu off a 2pole breaker to feed this transformer (with a ground).
This is causing the ground to deteriorate.
My question is do f you think a transformer already getting 240v on one line can handle a second 240v so the transformer load would be balanced better.
